lincolnmatthews
Aug 27, 2013Explorer
What are my options with a DRW 1 ton 99 Dodge?, although I'm not driving in AK I do quite regularly drive on some pretty rough roads with my old 880 Lance. I'm tired of worrying about my tires,(currently stock size Toyo's). I thought about 1" taller for more ground clearance & less RPM's. (I've got 4.10 axles) But then figured it may give me more side wall flex, which I don't need hauling the camper.
I thought about 19.5" whls but don't know if you can get them with a dual setup?.
Seems like I have to air up every month (truck sits alot on concrete with camper on) is it normal for the tires to leak off over a month's time? Maybe 5-10lbs. Just replaced a wheel because it was leaking thru the steel rim, how's that possible?
I assume that stock tires are a load range D w/2py sidewalls? I would like 3 or 4ply side walls, & can one get higher than E rating? Sorry for all the questions, I'm just not knowledgeable about tires that much. I will have to research this better.
44,068 PostsLatest Activity: Apr 17, 2021
