jimh406
May 14, 2013Explorer III
Jeff, what makes you so sure that people who don't have a DRW have never driven one?
Yes, you are more likely to get door dings. It's not your door opening that you have to worry about. A SRW can cheat against one line in a corner parking space to gain effective space on the other side. The DRW can't go over as far because the wheel/fender sticks out.
I'm happy for those of you that can't tell a difference in the spaces for where you park. That's not the case for many of us. I don't drive my truck to work now because I can only park it in a very few spaces. I can literally be blocked in by people being legally parked. The spaces are barely wide enough for a SRW if you want to stay inside the lines. Like it or not, a DRW track is wider. I would have bought a SC SB GM if I knew I was going to work where I work now, no, it would not be a DRW LB CC. :) I would have had to bail on the Ford. I bought the Ford because it was the most capable diesel that would fit where I had to park at work.
As far as length is concerned, Ford's are longer than Chevys from cab forward, and crew cabs are longer than a super cab. You don't have to like it, but that's the truth just like if the turning radius barely works for a short wb supercab, a DRW CC is going to be a major pain in the neck. Most DRWs seem to be CC. Some people have SRW CCs. Those would be the same length, but for the most part a SC isn't even an option for some DRWs.
Just because you don't have to deal with it doesn't mean it's not true.
44,070 PostsLatest Activity: Aug 05, 2026
