jstaffon wrote:
marcsbigfoot20b27 wrote:
How much money is too much for a battery? as in what is your budget per battery?
Why do you have to move the batteries so much? .....to fill them with water?
For $180 each you can get an AGM deep cycle 105 amp hour 12 volt  made by East Penn/Dekka that has almost ZERO maintenance and is more forgiving than flooded batteries....made in USA.
I guess I don't move them much but when I do move them it's very hard for me to bend over with that much weight. I've had a couple back surgeries. I guess the more I think about it, I only moved them in my old camper. My new Rockwood has a switch to isolate the camper from the batteries so I can leave them in the camper. $180/each is well within my budget. Would the DC31DT be a comparable battery?
Theses batteries made by East Penn don’t need water so you won’t have to move them to check. Good reviews.
https://www.samsclub.com/sams/duracell-agm-deep-cycle-marine-and-rv-battery-group-size-31dtmagm/prod3590232.ip;jsessionid=3F2F266AD0C17E1D95F23D80627CCB54.estoreapp-44276360-28-284912448?navAction=push
