Can someone please explain to me how and when Ford 250s got a 10,000 GVWR and payloads that high? I've looked at numerous Fords and they were all 9900 GVWR with payloads less than 3,000 pounds (in the CC configuration).
When ??
In '05 Ford gave the 6.0 a 10k GVWR then continued with the 6.4 and 6.7 till 2012 when they mover to the 9900 GVWR or a 10k GVWR ...as was mentioned probably for licensing in those states/provinces that use a GVWR for that purpose.
How ?? Guessing but IMO Ford as Dodge and GM increased engines/transmissions/frames/stronger axles/etc which can make a higher GVWR.
Now just too muddy the GVWR game is a Ford F350 SRW which comes in several GVWRs and also a 10k GVWR on up to a 11500 GVWR for the same exact truck.
So goes the GVWR based payload game.
