kells81's avatar
kells81
What do I need to add to my truck to tow my RV?
First post,
This may seem like a dumb question but here goes....
I recently had Dodge buy my 2011 Ram 2500 back as a lemon. To keep a truck at the house I traded my wife's 2011 charger for a 2012 Laramie Longhorn 1500 and just pocketed the cash since I work overseas and don't need a vehicle anyway. The truck has the built in trailer brake, tranny cooler, tow rating of 9,600(oddly my 2500 only had 11,500), 7 pin and class IV hitch.
Trailer is a 2012 Crossroads Longhorn Texas Edition 27RL. Dry weight is 6520, gross is like 7600-7700, hitch weight is just shy of 700. I don't tow it with fluids in it (freshwater is in back so this may mess with the balance). Doesn't really have much in it other than a couple sets of clothes for me and the girls. Cooking utensils, and a small light flatscreen tv.
Towing will be recreational, maybe once or twice a year to Corpus, Galveston, or to our farm up in OK. All are about 5-7 hours away. I towed it before with a regular hitch with no issues with sway on the 2500 but no chance to with the 1500. I have the dealer getting the correct tow mirrors for this truck but not sure what else I need to get. I am pretty sure a WD hitch is a given.
  • If your hitch weight is 700 on a 76-7700lb TT then your too low. Needs to be at a min 10%, which is 760-770. Should be closer to 12% for optimum balance. 12% of 7600 is 912lbs. Average Ram 1500 Laramie Longhorn payload is in the 1200-1230lb range. 1200lbs - 900lb for TW and you only have 300lbs left. Even if you went with the 760-770lb 10% min TW you would only have 430lbs for passengers and cargo in the truck. Those are the reasons why everyone is saying you'll be over payload capacity. Just curious, have you ever weighed you TT?
  • Sorry, just saw you said the hitch weight is 700 lbs. It will be close, but you should be ok.
  • You payload rating is around 1300 lbs and your trailer is going to use about 900 lbs of it. That leaves you with 400 lbs for your passengers, truck accessories, hitch, gear, etc.
  • hes refering to your leafsprings. get hooked up and see if she squats. airbags are a good addition to keep her level. onboard air and wireless controllers are cool if you have the dough, but not needed. cigarette lighter bike pumps work just fine.
  • boosTT wrote:
    You are going to be over your payload. Get air bags. I have air lift 1000s and an wireless one compressor on my 2011 ram 1500.
    How do you mean I will be over the payload? Im not exactly sure what your referencing.
  • You are going to be over your payload. Get air bags. I have air lift 1000s and an wireless one compressor on my 2011 ram 1500.
