RatedX's avatar
RatedX
What do you use to stabilize when parked?
After my first weekend of camping, the one glaring thing I need to take care of is how I stabilize my TT when it's parked. This weekend I used Misc pieces of wood, but someone recommended I get jack stands for this.
Any suggestions?
  • I just use 2x6s to give a flat surface for the jacks to be on, as well as to keep them from having to be overextended. Then, I use a cordless drill to extend/retract the jacks. So far, so good.
  • Rated X
    in your bing or google address bar type in "the utility block"
    This looks like an awesome leveling block also you can go to you tube to watch a video just type in ( the best utility leveling block )that seems to be the an awesome way to go
  • I put blocks of wood or levelling blocks underneath my jacks. The further extended they are, the less effective they are. So I usually put stuff under even if it isn't necessarily needed.
  • RatedX wrote:
    I should of specified that my TT is a 2011 and has scissor jacks on each corner. The challenge is that most time they won't touch down directly because of height so I have to meet them halfway at least.
    So I am looking for best solution for that specifically. Looks like your picture of jack stands is exactley what I am looking for, just wanted to grab opinions to make sure it's the best route.
    Lynx Levelers are great. The fit together, and make a nioce platform for the stab to sit on. And they clean, and store easily.
  • I should of specified that my TT is a 2011 and has scissor jacks on each corner. The challenge is that most time they won't touch down directly because of height so I have to meet them halfway at least.
