valhalla360
Jan 03, 2018Navigator
ShinerBock wrote:
We all benefit indirectly if these type of fleets start using longer drain intervals. Just think of how much oil would be saved if these fleets(or everyone) switched from a 3k or 5k drain intervals to 10k or 20k intervals. That would save A LOT of oil from being used making a huge impact on our dependency on foreign oil and less money going into the hands of people that use that money against us. Sure, an unneeded 3k mile oil change interval is "cheap insurance" to one guy, but multiply him my hundreds of thousands every year and that becomes a lot of wasted oil.
I think you are way behind the times. Most new vehicles are in the 7-15k range for manufacturers recommendations. A lot of new vehicles actually track usage patterns and adjust the recommendation based on that.
It's been years since manufacturers have recommended 3k between oil changes.
The problem is taking it beyond 20k for other than high mileage commercial fleets quickly runs up against the law of diminishing returns.
Example: You have a new $50k diesel pickup and will sell it at 150k miles.
- If you use 10k intervals, that's $50k plus $1500 (at $100each) for oil changes for a total of $51.5k.
- If you go to 20k intervals, it's $50.75k...or a 1.4% savings. Of course if anything goes wrong due to the longer interval, you likely lost far more than the 1.4% savings and those issues are most likely to happen post warranty and even if during the warranty, if they can show you didn't follow the recommended schedule (many track oil changes), they can deny the warranty (often even if not really related to oil changes).
Even worse for gas pickups as I still usually get oil changes for $20-30 each but a new gas pickup is often in the $30k range. Saving 7 oil changes at $30, is only $210 over a similar time frame.
44,056 PostsLatest Activity: May 04, 2014
