wnjj
Sep 26, 2014Explorer II
bobndot wrote:deltabravo wrote:Super_Dave wrote:
A short bed camper does hang farther off the back of a long bed truck due to the storage cabinets typically found on a short bed model.
A shortbed camper shouldn't be put on a long bed truck because the center of gravity will most likely be behind the rear axle.
It would look goofy as heck too, siting so far back on the truck.
Isn't the added bed length between the axle and the trucks cab ?
The SB camper should sit in the same place in a LB. The COG remains in the same place, in front of the axle.
If you google pics of SB campers on LB trucks, you can see where it sits. The open space that is now between the cab and the camper can be used for storage or build a custom box .
here is previous info on SB/LB
http://forums.woodalls.com/Index.cfm/fuseaction/thread/tid/27471882/gotomsg/27475612.cfm
Correct. A short bed model on a long bed truck will have the same COG relative to the rear axle assuming it is located due to the rear overhang storage and cannot slide further forward in the long bed.
Inversely, a long bed model on a short bed will have its COG 18" further rearward (relative to the rear axle) than on a long bed because both are located by the front of the box.
The funny thing is many manufacturers take a long bed model with whatever COG it has and add more weight to the rear as storage and declare it a short bed model. Clearly there are no absolutes with COG "design."
44,027 PostsLatest Activity: Mar 05, 2025
