valhalla360 wrote:
As far as the name, you could as easily say an inverter CONVERTS from 12vDC to 120vAC and it's true ....
You can't convert AC from DC.
You have to invent AC current using electronic devices and then you can convert to desired voltage.
Over the years converters went via several designs.
Back in 1980's they would supply 12VAC for RV lights and water pump, when small DC circuit would charge the battery and operate radio.
Then some designs put 12VDC converter parallel to the battery, some disconnects the battery from RV when on converter.
That surprised me lately as 20 yo converter was showing 18V on new digital gauge.
Took few forum experts (not on this forum) to figure out that converting AC with electronic circuit, the voltage spikes high for microsecond, before it levels at ca 12V.
Analog meters will not register it, some digital multimeter will not register it, but cheap meter that come with lighter socket does.
