Geewizard's avatar
Geewizard
What is a 3/4 ton pickup?
Since we all drive campers with pickups underneath, I suspect many will have an opinion to this question: just what constitutes a 3/4 ton pickup? Axle capacity? frame strength? brakes? GVWR? Payload? Hearsay? Common knowledge? The grocery store checkout person?
I ask because my Tundra has a payload of 1600-1800 lbs (depending on what you read). That makes it a 3/4 ton pickup in my mind. I've been hauling 1600 lbs at least once a week since I bought mine new. And there's no issues (other than one wheel bearing self-destructing at 89k).
This is a serious question, not a post to incite a riot.
thanks
  • I think all pick ups are half ton. To make 3/4 or one ton rating it has to have diesel, 4wd, air bags and stick shift.:)
    Geewizard, can you tell us what fuel mileage you get with your Toyota and camper?
    Thanks, I'm might be going to downsize someday and think that is a simple way to go.
  • Call it relative,not antiquated.
    * 1/2 tons "typicaly" have payload in the 1500-1700# range
    * 3/4 tons "typicaly" have payload in the 3500-3700# range
    * 1 tons SRW "typicaly" have payload in the 5000# range
    * 1 tons DRW "typicaly" have payload in the 6000# range
    The above are "typical" capacities and can vary quite a bit based on 2 wd / 4 wd,. cab style, etc
    Of course there are upgrades wheels/tires/brakes,frame/ etc associated with the increase in capacity
    B
  • And something like a F550 would be a 4 ton pickup.
  • In truth. there is no such thing as a 1/2 ton, 3/4 ton, or even a 1 ton. Those are antiquated labels, used just so folks won't have to name the series, Like F100, F150, 1500, 2500, F250.
    As you have pointed out, your socalled 1/2 ton is much closer to a 3/4 ton than half.
