PaulJ2 wrote:
So--I can assume when a 24ft trailer is advertised it may just be from the ball to the bumper instead of the actual box? I guess bring a tape measure along.
From what I have found, you can't assume anything. It's amazing how many different ways to measure an RV are out there - which way used is dependent upon what the person measuring wants to accomplish. The manufacturer usually has both measurements available, but the seller often lists one or the other interchangeably as "RV length". If you're lucky, you find the two measurements listed side by side.
