JIMNLIN
Dec 28, 2018Explorer III
If the rear axle is the same as used in a cab chassis version, then I get that. I looked at one recently and could have sworn it said 4500ish payload.
According to the clicky I left you the F450 pickup and cab & chassis both use the M300 Dana....different spring packages plus the CC has larger rear brakes and a larger diameter rear axle shaft (1.64 dia/41 spline vs 1.47 dia/37 axle spline)
Spend some time and look through all the clicky link super duty 250/350 srw and drw/450 pickup weight specs and 350/450/550 cab and chassis specs. Just about all the answers are there for weight specs and mechanical same as...... or the differences.
44,056 PostsLatest Activity: Jan 12, 2020
