”For finding damaged or rotted wood, that gets a bit harder, either will have to remove the roofing and siding and replace from outside or gut the inside and repair from the inside.
Can be done either way but do be aware, removing the roofing and siding will most likely result in the need to replace some or all and that can be difficult and expensive to replace. Siding must be remved starting from the bottom and work your way up and will be held on with millions of nasty staples at the bottom of each piece of siding.
IF you have visible damage to the inside paneling or ceiling you might be able to spot remove the affected areas in sections and iff lucking not have to disturb cabinets and interior walls.”
”Removing roofing and siding will most likely result in the need to replace some or all” of the wood or siding? thank you for your help.
