"Only 87,000 on an 01??? You don't drive it enough!!!"
100% correct. 3 miles from work. That was a before retirement. Used to take it out on weekends to give good work out. Now that I'm retired it gets to go to work pulling wives trailer around.
"Radiator hoes clamp, your starting to sound like Fish!"
Just sort of irritating to me that so many products are advertised to "walk on water" when most people know manufactures claims are mostly BS. The latest that caught my eye is the Willow leaf thing on TV. Supposed to cure knee problems. How can a flashing led plastic thing do anything with knee problems?
" I hope you replaced the Lift Pump with an aftermarket, and a Fuel pressure gauge, and never see below 14 psi."
Fass system with led low pressure light in dash. But I think it only lights up if fuel pressure goes under 5 pounds. Full gauges and egt probe stuck in at hottest spot.
