Hemi_Joel
Mar 25, 2017Explorer
My 2006 Arctic Fox 1150 is amazingly well thought out, including the light switch that you can reach through the doorway while standing on the ground. If there is anything dumb about it, I am only aware of two: The furnace is in the slide, so there can not be any ducting to the bathroom or the bedroom. Also, the drive motor for the slide is supposed to be mounted on a shaft between the 2 gears that move the slide. AF chose to mount it to the rear of the rearmost gear, and that causes timing issues between the two gears.
