cmcdar
Apr 15, 2017Explorer
Johno02 wrote:
Ours has an access hole for the sewer hose to go through, but the connector on an standard hose will not go through it. Solved the problem by making a special extension, and put the connector on the hose after putting the hose through the access. The access port needs to ve less than 1/4 inch bigger to fit right.
My camper you had to go up and into the dark camper to feel around for light switches.
On of my first mods was to add a battery operated, LED, motion sensitive, wall sconce.
It comes on the moment the door is opened and gives enough light to see around the camper and turn on the desired lights.
Motion Sensor LED Wall Sconce Night Light
