Trekkar
Jun 12, 2022Explorer II
valhalla360 wrote:theoldwizard1 wrote:valhalla360 wrote:
... more expensive and more maintenance but combining a pair of 2000w generators is also viable
Personally, I would go this route instead of the much heavier 3000+W generators !
Assuming you are reasonably healthy, the bigger unit is my preference.
Only lifting is in or out of the truck (it sits just inside the tailgate). After that it pulls around on wheels.
The lifting is offset as the bigger units often come with electric start. If you are physically limited, yanking on the pull cord while bent over is likely to be challenging.
The Champion 3400 has a nice handle / wheel set up for moving it. I just walk it up a lightweight truck ramp onto the truck. Easy.
44,070 PostsLatest Activity: Jul 01, 2022
