Tony_B
May 03, 2017Explorer
What Size Truck?
I just put a deposit on a new 5th Wheel the Spes Show: Dry Weight 10,107 lbs Payload 2,085 Lbs Hitch Weight 2,029 Lbs What size truck do I need...
Bionic Man wrote:
I would be willing to bet that the cargo capacity that the OP has posted is the cargo capacity of the trailer, not what the pin weight will be. That would put the GVWR for the trailer at 12,000 and change. The hitch weight of 2029 puts it into the territory of just about any newer 250/2500 truck. If you want room to grow, look for a 350/3500 SRW.
Or, in RV.net fashion, you HAVE to have a DRW, otherwise you are putting everyone on earth in jeopardy..... ;)
