Tony_B
May 03, 2017Explorer
What Size Truck?
I just put a deposit on a new 5th Wheel the Spes Show: Dry Weight 10,107 lbs Payload 2,085 Lbs Hitch Weight 2,029 Lbs What size truck do I need...
IdaD wrote:
You don't need to limit yourself to one tons for that size fiver. Since you're buying used that's an important point to consider as it would eliminate a significant percentage of inventory that's available. Tire and axle ratings are the critical limits you need to consider on 3/4 tons, much more so than the payload which is nothing more than GVWR minus curb weight at the factory - in many cases it means nothing.
