Tony_B
May 03, 2017Explorer
What Size Truck?
I just put a deposit on a new 5th Wheel the Spes Show: Dry Weight 10,107 lbs Payload 2,085 Lbs Hitch Weight 2,029 Lbs What size truck do I need...
STEVEO496 wrote:Tony B wrote:
would a diesel 6 cylinder like a Cumins 6.7 pull my 5er with a GVW of around 12,300 lbs?
Absolutely, all over the road semi trucks have 6 cylinder engines and pull 80k lbs all day every day. What you really have to look at in an older truck with higher miles is the transmission. The engine itself could easily go for over 500,000 if serviced regularly.
