Groover
Jul 21, 2017Explorer II
An awful lot depends on whether you stick with the small trailer or might upgrade to a bigger trailer someday. For the trailer that you are looking at any truck will work fine. You don't need trailer tow mirrors, weight distributing hitch, tow package, etc. But if you do happen to upgrade, which happens quite often, it will be a lot less expensive to already have that stuff than to trade trucks. I am wondering if that trailer comes with brakes. Be sure that it does. Trailers that small often try to sneak by without them and brakes are not legally required unless the trailer is over 3,000lbs and your dry weight is less than that. If you are getting electric brakes the factory controller is very nice. I have a trailer with hydraulic surge brakes and there is nothing wrong with those but you rarely see them on a camper. You don't want to increase your stopping distance by 50% to save a few hundred dollars on brakes. That trailer is less than 8 feet wide so I would say that the trailer mirrors are a wash. I have them, they have some great features but they also get in the way sometimes. Get at least the basic tow package, it doesn't cost much and doesn't hurt anything. You don't need a weight distributing hitch or sway control for that small of trailer, your truck is rated to handle twice that much on a standard hitch. I would be tempted to get the 2.7l engine for what you plan to do. As far as what you plan to do, there is a pattern of upgrades that many have experienced. Personally, I started with backpacking, then a popup, slide in truck camper and now a 35' diesel motorhome. They all have advantages and drawbacks. Also, it has taken 35 years for me to do that and I wouldn't have kept the same vehicle all the way through regardless. One more thing that you may want is the 6.5' bed. It is kind of hard to find but that extra foot gives you a lot more cargo space.
