JIMNLIN
Jul 20, 2018Explorer III
Actually there are a number of 2018 F-150 5L configurations that have payloads in the 3,000 lbs range so payload may not be an issue
That 3000 lb payload is a gvwr based payload.
There is no F150 that has enough RAWR to carry 3000 lb payload in the bed.
About the most the HDPP 4800 RAWR can carry in the bed is in the 2400 lb range depending on cab/drive train selections.
Fords F15o has 19 different GVWRs from 6000 on up to 8200 lbs
F150 has 5 different RAWR from 3300 up to 4800 lbs. Plus all the cab/engine/drivetrain selections.
Like others are asking....we need your trucks GVWR/RAWR/axle ratio/etc to give you a good recommendation on max size TT.
