tonyamsler wrote:
... snipped ... First time truck camper purchase - 8' Skamper pop-up. Looking to purchase a used truck for my possible cross-county trip. Most are saying I should be looking at a heavy duty truck like the F250 or GMC 2500, rather then the light duty (150's and 1500)
Hey Tony, good on you to get input from knowledgeable people beforehand ... I wish I had done that when I bought my HD truck and later bought our TC. There is a good reason "most are saying" 3/4 to 1 ton HD truck (250o or 350o) series. I'm also of that opinion because that is what would best serve your current and potential future needs.
I would also make sure that your used HD truck purchase came with certain must haves like front and rear anti-sway bars, camper package (usually including heavier or overload springs), factory trailer hitch and lighting harness, tow mirrors, possibly a heavier battery/alternator, possibly an upgraded cooling system including a tranny cooler and maybe even an integrated brake controller if it is a later model used HD truck.
For used HD trucks, every brand (Dodge, Ford & GM) have their good and troublesome generations. Take Ford for example, their '99-2003 7.3l diesels are generally considered bullet proof for diesels. On the the hand, their 6.0 and 6.4l diesels can be money pits and people generally recommend to avoid them etc. The gasser 5.4's are rock solid if a little underpowered and their later year 6.0l V10's gassers are considered very good. The newer 6.2 gasser is great but has a drinking problem and the new 6.7l diesel is proving to be a reliable, powerful powerplant. Can't speak to the GM or Dodge crowd ... maybe some of those owners will chime in here.
I suggest you go to each brand's reputable truck forums (like the Ford Truck Enthusiast for Ford trucks) and do your own research. It won't take you long to zero in on which generation(s) and engine/tranny combo's to consider and which ones to avoid. A few hours of research time invested now will save you hundreds of hours and thousands of dollars of wasted money in the future.
BTW - you are doing it right knowing the TC you are fitting to and then buying the right truck to match it. Many of us (me included) had the truck first then bought the TC. Sometimes we end up putting lots of mods into our trucks making them "able" to handle a load above their legal weight rating. You should also consider this as you may wish to upgrade your TC to something bigger/heavier in the future and having extra capacity to work with is always a good thing.
I hope this helps and good Luck. Make sure you let us know how things work out for you. The next person with a similar situation will benefit from your decision and feedback.
