Moser
Aug 28, 2019Explorer
I have the same year truck, the problem that is common with those is the door to recirculate the air will break. My fan worked fine, however there was insufficient cooling, thought it needed recharging, had it checked and that was fine. I came across other people having this issue, I checked the door and found mine had broken and was not allowing the air through. I removed the door and it has worked perfect since. Plan on replacing it someday. It is easy to check, remove the glovebox and you will be able to see the door. You should be able to see if it moves by putting the AC on max.
