Huntindog
Aug 28, 2019Explorer
Moser wrote:I would agree to that possibility, except it works great for long stretches of time. That points to a freeze up. Possible other parts would be resistors etc... But the same detractor from that thinking is again.... It works great for long periods of time.
I have the same year truck, the problem that is common with those is the door to recirculate the air will break. My fan worked fine, however there was insufficient cooling, thought it needed recharging, had it checked and that was fine. I came across other people having this issue, I checked the door and found mine had broken and was not allowing the air through. I removed the door and it has worked perfect since. Plan on replacing it someday. It is easy to check, remove the glovebox and you will be able to see the door. You should be able to see if it moves by putting the AC on max.
