Perrysburg_Dodg
Feb 06, 2017Explorer
If the vehicle has anti-lock brakes you can remove the sensor and using a rubber tipped grease fitting add some good full syn grease to the hub. have someone rotate the hub has you add the grease just don't go crazy with it! Works great will be doing mine this spring when the weather breaks.
X2 on the cheap interweb hubs on trucks! Cars are fine but they are to cheap for HD trucks. Stick with the OE or a good parts store brand like NAPA Gold hubs. BTW adding some copper high temp never-seize will make changing them the next time a whole lot easier trust me!
Don
Don
44,061 PostsLatest Activity: Apr 08, 2026
