smcrea
Jan 26, 2015Explorer II
Wheel Size
Hi Guy's, I have one more question before I pull the trigger on my New Truck Factory build THIS WEEK!!.. Yes I need to order it this week on my F350 SRW Powerstroke 6 3/4' bed big cab :-) We're ...
Need-A-Vacation wrote:
Larger wheel generally will give you a rougher ride. See if the dealer has couple trucks (2500 or 3500srw-any motor) with one of each wheel size. Take them for a drive to compare down the same roads, stay in the same lane, etc.
Personally, I would probably go with the 18's. Better tire selection, little better ride, etc.
Our truck came w' 20's (bought off lot), and there are a few more tires recently available that will fit our truck (GM's don't like larger tires (much taller) without rubbing). I have been back and forth to switch to 18's for the little better ride and better tire selection. Stock we have 32.5" tall tires, can fit 33" tires, but 34" will rub as I understand.
BUT.... If the Ford allows you to mount a taller tire without any issues then go with the rim you like the best. If thats something you would consider.
