To me, ANY tire with a 75 or less profile tread to sidewall height is a low profile tire. You can get 50 and 55 series tires that are upwards of 35-38' with 22 and 24" rims on semi's. Those are still low profile tires due to the 50-55% of the tread width in sidewall height!
There are positives to an equal height lower profile vs higher profile tire. ie say a 265-75-16 vs a 265-70-17 tire. Both the same overall diam, same revs per mile etc.....
At the end of the day, it in reality is up to you as to which will serve you better.
Marty
