Okay, so I am looking at going going up to 185's from my 175's.(175/80R13) the problem is it looks like my tires occasionally rub the inside of the fenders. can I put 8mm wheel spacers on a trailer? w...
If you currently have 13/16" or more of visible threads with a nut off, you should be good. Longer studs are available if needed. I'm not a fan of using spacers because trailer studs locate the wheel and some addition stress would be on them. 8mm isn't much, so use your best judgement.
