bmanning wrote:
SolidAxleDurango wrote:
bmanning wrote:
You're thinking like that which you are-- an educated RV & tow vehicle enthusiast.
The average person has no clue about GVW, GCWR, etc etc
Key to marketing sometimes is to "dumb it down" to speak to the majority.
As neat (and progressive) as it'd be to see change, half-ton, 3/4' and 1-ton terminology won't be going anywhere anytime soon.
I'm not suggesting the marketing material go away.. Just that when we discuss things here, we use measurable and specific rating (I.e. The numbers)...
You're right, it would likely work on this forum as at least most here understand the numbers.
Disagree...even too much of the advice given indicative of not
understanding the numbers themselves, or what rating means.
How many times will someone say they are rated for XX,xxx lb trailer
because they read it in their manual. AKA...MTWR, but out of context.
How many times have 'some' tried to inform them that they need to go
out and weigh their setup to truly know what their 'actual' MTWR is
Or how many times will you read advisers here say GCWR is meaningless
Etc
Surprised someone hasn't posted a nice list of different brands & model years and their accompanying GVWs & GCWRs for reference.
Too many and confusing to most of the herd
Plus with this pure marketing verbiage...it covers every thing and
across many eras.
My 1980 C10 Silverado Big Ten (half ton of that era and the HD version
to boot) with a 6,200 lb GVWR was the BIGGER half ton of that year.
Regular half ton's of that year less than 6.2K GVWR
Today's regular half ton is in the +7K GVWR range
Then again it's Sunday, football's on, and making that list would be dangerously close to work.
There are many who will advise newbies that they can do it, as they
also have a half ton of the same badge (OEM)
Have been doing that for loong time with no problems
Have had 2 or 3 (can't remember anymore) PM me asking what the...
One guy wanted to sue the guy advising that he could do it. That
guy had one of the smaller GVWR 'half ton' from that same OEM, but
since smaller GVWR...burned up his diff and wanted to sue the adviser
The other guys said the trailer manhandled them, but how did that advise
buy do it?
Well, it turns out that those advisers have the "HD" version of half
ton for that same year, same OEM and had a +8K GVWR...well over 2,000
more GVWR...but still a 'half ton'...
