- CavemanCharlieExplorer IIII hate to do it until I have too. I wait till if falls below freezing for several hours. Most of my fresh water pipes are inside my TT. If it looks a little cold I just leave the heater, and water heater, run at night to keep things above freezing.
It depends on what type of TT you have. - FishHaggisExplorerWinterizing today as its hovering around freezing.
- Thom02099Explorer IISome good advice from folks above. What you DON'T want to do....
What I did last year. Made my appointment during the last week in October for early November, a time when we were having daytime highs in the 70s, lows in the upper 40s/low 50s. Two days before the appointment, it was 74 degrees. But then...the temp fell below zero the night before I was to take it in, and was in single digits on my appointment day. They had to put the trailer inside to warm it up before they could do anything. And I was not alone.
Yeah...my bad. To paraphrase a current DirecTv commercial..."don't be THAT me"! :S :o - tatestExplorer IIBefore you start having temperatures below freezing for long enough to freeze water in the lines.
That is something that depends on where the RV is stored, and whether the plumbing is exposed or protected.
Where I live, before the end of October. If I use the RV between October and April, I will dewinterize as I move to a warmer place, rewinterize before going back to cold storage. Actual dates would be different if I lived in Minnesota or Mississippi. - PAAKExplorerI am doing my this weekend sinceI know am done for the season due to upcoming travels with my job. Watch te night time temps, and if your done, then prep it.
- FishHaggisExplorerIf you are not doing it yourself and going to a dealer, book something now to avoid the fall rush.
- valhalla360NavigatorAre you done using it for the year?
If yes, winterize now.
If no, you either take a risk or winterize between trips.
Personally, I prefer the head south option. - DavidPExplorerBefore winter sometime after fall.
- beemerphile1ExplorerNever, head south where it won't freeze.
- downtheroadExplorer
bobndot wrote:
You need to watch your night time temps. When you expect those temps to drop below freezing , its time to winterize.
Unless you are not planning to use your rig, then do it now and you won't have to worry about anything.
Good advice here.
I have been RVing for 25+ years and I still have the same question...
"When should I winterize?"
All I am sure about is that I don't need to winterize June-Aug. and that only is true for where I live. The rest of the year...????
44,025 PostsLatest Activity: Feb 18, 2025
