BarabooBob
Jun 26, 2020Explorer III
I run my fridge on lp while traveling with the exception of when going through the tunnels on the east coast under the big bays. They have signs all over the place that propane must be turned off. I have seen tunnel/bridge authorities pull RV;s over to check them.
I installed a 6 gauge wire from the power distribution center under the hood to the rear of my truck and connect it to the battery on the trailer with an Anderson Powerpole connector. A circuit breaker is at both ends of this to protect against shorts. When I statt my truck, my volt meter in the TT jumps to 14.4 volts. I have checked to see what amps I am getting. I also connect my solar panel/controller to this same plug when we get set up.
44,066 PostsLatest Activity: Jul 25, 2018
