RavensFan24's avatar
RavensFan24
When will gas stations start truly accommodating trailers?
After a 2500 mile trip and several gas stops, I've come to the conclusion that gas stations make no effort whatsoever to be accommodating to people with trailers. From the way pumps are lined up in their lot, to the tightness of getting in and out, right on down to where they hide the air pumps (assuming you can find a pump that actually works). IT doesn't make sense to me that you'd have a giant lot for people to drive and park in, but then leave no room to get in and out of the pump areas or even to access the air. I tried 4 diff't service stations trying to get air. The first I was able to get lined up and close enough to the pump only to then realize that there was a quarter stuck inside the machine and thus it didn't work. The 2nd place I found would've caused me to block an entire entrance to back in to a spot where there was free air and a working pump. The 3rd place was hidden in the corner in a parking spot, which someone inevitably always parks in and the 4th place had no connector to actually be able to put the air in the tire.
Also, side note......when will people realize that gas pumps are not parking spots. You pull up, fill up, and move out of the way. Don't park there, go inside, take a dump, browse for snacks, chat with people and then come back 20 minutes later to move your car and leave.
Sorry I had to rant and the gas stations won't listen to me. I felt like at least complaining to other people that deal with the same thing would make me feel better. :)
