RoyBell's avatar
RoyBell
Where is this water coming from?
I was working on the camper last night and it was raining out. I closed it up for the night and had a flood inside.
The water all appeared to be coming from the front inside corner of the slide, like under the carpet. Is it possible to get water to that point from the roof/sides that were wet?
It's a new trailer, just bought it last week. I was expecting a little water, but there was probably about a good cup full.
I opened it back up and left it over night. It wasn't raining this morning so I wiped the sides and roof down, put the coach at an angle and did not see any water drain off. I put it back up and put the slide back in and there was a little water seeping back out from the same corner. I am hoping it was just left from yesterday.
Is there something wrong here? I just don't understand how water on the outside can get to what is essentially under the carpet on the slide. It appears the black plastic wrap is acting as a rain gutter and collecting the water. Is it possible the water that was on the roof made it's way down there when I closed it yesterday in the rain?
It is supposed to rain this weekend and we are making the maiden voyage. I would like to prepare for this and glad I saw what happened at home and was able to dry it up before any damage occurred.
20150612_054825 by RoyBelluomini, on Flickr
  • donn0128 wrote:
    More than likely from the slide roof. When you close a slide without first cleaning the roof off, what ever is on the roof comes inside. Thats one reason people install slide toppers.
    Vote 3 here
    X2
  • I will check the seams. I looked this morning and all seemed OK when I was drying it off, but wasn't looking specifically for cracks. It's a new camper and I find it hard to believe it would be cracked.
  • Check all the flashing around the slide. I just had to replace the flashing at the bottom of the sides of my slide because the plastic had cracked and was letting water in. I got to checking all the seams, vertical and horizontal, around the slide and found a lot of separation, potentially letting water in. Look real close because mine was a very narrow bead of caulk. I used a pocket knife to cut out the bad spots and recaulked them. Yearly checking is vital in the fight against water intrusion.
  • Windows are fine. No leaks inside the camper while slide was out.
    If from the roof, how does it get caught and collected in the plastic wrap? This has me a bit concerned. If caught in the plastic, it will have a hard time escaping and I imagine want to just sit there and rot the wood. I put a fan on it this morning to help dry it out while at work.
    I am hoping it was user error and just from the roof so that it can be prevented in the future. I have been looking into the slide canopies before this happened. Now it's a bit more motivation.
  • More than likely from the slide roof. When you close a slide without first cleaning the roof off, what ever is on the roof comes inside. Thats one reason people install slide toppers.
