Tvov
Sep 30, 2016Explorer II
JIMNLIN wrote:
All you need to do is lift one end of the axle instead of the whole side of the trailer.
Jacking under the axle next to the U bolt or the U bolt itself on a std leaf spring suspension works fine and there will be no damage to the axle.
If your going to lift one side of the trailer from the frame I would suggest using two jacks next to the farthest apart spring hangers. That way less chance of a bent frame from a single jack point on a heavy trailer.
Whatever method you use make a dry run at home.
Agree with all this. Practice at home! I found that the jack for my truck works fine to change a tire on my trailer - actually, the extended handle for reaching under the truck is perfect for getting under the axle of my TT.
Make sure you carry a socket and/or lug wrench that fits the lug nuts on your TT!
And... check the air pressure in your spare tire.
