jmckelvy
Oct 16, 2014Explorer
kerry4951 wrote:
Mines under the plastic pull out bin that is inside the cabover step that you use to get into bed. I lifted out the bin and installed a 1000 watt Pro Sine wave inverter. .......Also a nice place for using short cable runs to the batteries in my 1140.
I did the same on my 990 but with a slightly smaller inverter. The inverter I installed came as a kit with a standard size wall receptacle containing a remote ON/OFF button, 2 USB ports and a dual AC outlet with a cable interconnecting them. I installed the receptacle in the side of the cabinet by the step to the overhead.
