ldsmith48's avatar
ldsmith48
where to put inverter on Northstar Pop up
I have a North Star 850 SC popup TC Thought I could install an inverter it in the compartment where the Batteries are. Instructions seem to advise against doing that. Any NS 850s out there that have installed an inverter?
  • How big? If 300 watts or less you can tap the main battery cable near the 12v fuse panel and wire direct into the 120v side with a transfer switch.
    Yes if you have flooded batteries in a tight compartment I would avoid putting the inverter in there.
  • Don’t install any electrical device in a compartment with wet cell batteries...the gas they give off will corrode the device. Is your battery compartment well ventilated?
