TBammer's avatar
TBammer
Where to run solar panel wiring
Has anyone installed solar panels on the roof of their TT? If so, how did you run the wiring? I don't see where I could run this through the walls, so it would have to be an exterior run. If so, any ideas on how to protect the wiring?
  • come down thru the roof / ceiling into a upper cabinent, then feed the rest thru interior routing. Our Terry has this "feature". The hole (sized for 14/2 ac wiring / romex or equivalent... 1/2 in hole maybe) is well caulked with dicor with no issue. The cabling on the roof is held down with standard cable clamps with screws (caulked accordingly).
  • Use one of the vent pipes for the holding tanks or refrigerator vent to get the wires down to a storage compartment near the battery bank/controller.
    See this site for lots of RV solar info:
    http://www.jackdanmayer.com/rv_electrical_and_solar.htm
  • or a tank vent stack. It will require drilling a hole in the stack inside and then sealing around the wire.
  • refridge vent. conduit. Exterior runs usually look like hell.
