Wrace
Nov 13, 2013Explorer
Which black tank chemicals break down waste?
When we are in camping mode our trailer gets the, use plenty of water each flush - make sure black tank is full - dump (or pump with macerator) - flush - add 2 gallons - repeat as necessary routine. I typically don't find a need to add chemicals during this process.
When we are not in camping mode our trailer is used as a guest house, or is parked/used at our remote farm property. In either case the black tank will be used occasionally and it will sit for months at a time. Over the last two years of doing this I add a toilet chemical to the tank and have had no problem dumping/pumping the tank after these long periods of inactivity.
I have been using a toilet chemical that was in a large bottle and one that I've had under the sink in the trailer for years. Some time ago I used the last of this chemical and of course given I have CRS I can't remember what brand/type it was. And I don't even know if it was a chemical that would actually break down waste or just a smell masker. It was a thickish blue liquid.
I would like to buy some more chemicals that are designed to break down the waste, not just mask the smell. I do not like the kind that is in the little plastic bags that supposedly disintegrate in the tank. The one time I tried those I found they disintegrated in the storage bag just fine. I would prefer liquid unless there is maybe some type of granular that would come in a small bucket.
What are my options for a chemical that will work on breaking down the waste over time?
Thanks
Thanks
