Cluck wrote:
My use - just me.. maybe a few lights, water pump, water heater (only as needed) and 13,000 BTU AC / ..I don't mind turning off the AC or Heat while other things need power - like the water heater. I would only use the water pump and water heater for an hour each night. Would never use Refrigerator, or other appliances.
The WH and air will be a big draw on the 2kw. You can do it, but the 2k will be screaming. And even a 3kw may have trouble starting the air.
What size gen do i need?3kw (3000) Honda or 2 2kw?Yamaha EF2400iS--will it run a 13.5 air? Honda EU3000 or Yamaha EF2400is? (2007) Why not cheaper for my needs? (2006)Official 2kw Champ inverter threadeu2000 run air 20113000 won't run 15k air?
