coolmom42
Oct 11, 2017Explorer II
myredracer wrote:
I've sometimes read some say that using the brake controller when you start to get bad sway is the thing to do. But in the OP's "split second" it takes to be involved in serious sway and possibly a catastrophic accident, how would you be able to find and activate the BC? I haven't adjusted ours and have rarely looked at it in years and wouldn't know where the SOL button is even if I had seconds to find it. I've gone to a lot of effort and expense to set our TT & truck up to prevent sway and it's never a problem. I wouldn't be towing at a speed that could result in bad sway to start with and would say it's partly about knowing the limits and capability of your particular TT and TV setup.
I encountered strong gusting side winds once which was kinda scary and was like driving on marbles and had to slow waay down to maintain safe control before pulling into a nearby rest stop for a while. Not the same thing as getting into a sway situation and should be towing at a much lower speed, if at all and def. not hitting the gas. TT blown over vid - RV crash to remember.
You should practice doing it before you need to.
