temccarthy1
Oct 12, 2017Explorer
Terryallan wrote:myredracer wrote:
I've sometimes read some say that using the brake controller when you start to get bad sway is the thing to do. But in the OP's "split second" it takes to be involved in serious sway and possibly a catastrophic accident, how would you be able to find and activate the BC? I haven't adjusted ours and have rarely looked at it in years and wouldn't know where the SOL button is even if I had seconds to find it. I've gone to a lot of effort and expense to set our TT & truck up to prevent sway and it's never a problem. I wouldn't be towing at a speed that could result in bad sway to start with and would say it's partly about knowing the limits and capability of your particular TT and TV setup.
I encountered strong gusting side winds once which was kinda scary and was like driving on marbles and had to slow waay down to maintain safe control before pulling into a nearby rest stop for a while. Not the same thing as getting into a sway situation and should be towing at a much lower speed, if at all and def. not hitting the gas. TT blown over vid - RV crash to remember.
Have a question. Do you not use the lever to check the brakes every time you hook up? While I don't need to adjust it. Shortly after starting out, I always pull the lever to be sure everything is working right. To me it is a natural as checking the tires, mirrors, or buckling up. I really want to know the brakes work before I need them. Easy thing to do, only takes a second.
But you do have to warn DW. she don't like bouncing her head off the dash. Is funny though
BTW. Sway can be induced at any speed.
X2 YES-- I always test my trailer brakes with the BC when heading down my street at about 20 to insure they are working! This should be on everyones checklist!
