SoundGuy wrote:
edatlanta wrote:
I had a EPDM roof that was properly maintained, not damaged, caulked frequently, etc. and at 5 years service the membrane started failing. Moisture was leaking through the membrane. This is obviously an expensive issue and the 12 year rubber roof warranty that all manufacturers advertise is totally worthless. Try to make a claim and see how far that gets you.
A misstatement of fact. The 12 yr roof warranty is on the membrane itself, not the trailer roof, and is not offered by "all manufacturers" but rather by the membrane manufacturer which in the majority of cases will be Alpha Systems. If your rubber roof membrane was thinning to the point where it was leaking before the 12 yr mark any claim would have had to have been made to the manufacturer of the membrane.
sort of picking nits here aren't we? it still boils down to an EPDM roof sucking.
bumpy
