edatlanta wrote:
I had a EPDM roof that was properly maintained, not damaged, caulked frequently, etc. and at 5 years service the membrane started failing. Moisture was leaking through the membrane. This is obviously an expensive issue and the 12 year rubber roof warranty that all manufacturers advertise is totally worthless. Try to make a claim and see how far that gets you.
SoundGuy wrote:
A misstatement of fact. The 12 yr roof warranty is on the membrane itself, not the trailer roof, and is not offered by "all manufacturers" but rather by the membrane manufacturer which in the majority of cases will be Alpha Systems. If your rubber roof membrane was thinning to the point where it was leaking before the 12 yr mark any claim would have had to have been made to the manufacturer of the membrane.
Bumpyroad wrote:
sort of picking nits here aren't we? it still boils down to an EPDM roof sucking.
Nitpicking? :h Either the roof is covered under warranty for 12 yrs or it's not - the correct answer is that
no trailer manufacturer offers a 12 yr warranty on
any roof. 12 yr warranties apply solely to the membrane itself and that warranty has
nothing to do with the trailer manufacturer which assembled the roof.
As I said earlier I'd personally prefer to not have an EPDM roof but the reality is that the vast majority of trailers are built using this product because it's the most cost effective method ... the fact that we as consumers have to later stand on our heads to ensure our EPDM roof doesn't leak is just one of many issues the RV industry at large should improve upon significantly but we all know that with current sales being what they are we're more likely to see a squadron of flying pigs than meaningful improvement in the RV manufacturing industry. :)
