SoundGuy wrote:
2012Coleman wrote:
Is THIS Your TT? If so, it doesn't weigh 4500 lbs, especially on a cross country trip with all your stuff in it.
Bumpyroad wrote:
GVWR of 6250 under tow limit of tacoma.
bumpy
GVWR is this case is irrelevant as there's no way one person is going to load so much cargo into a trailer with a factory UVW of just 4015 lbs and end up with a GVW anywhere near this trailer's GVWR of 6250 lbs. That said, the OP would be well advised to not be lulled into believing that anything less than a normally aspired V8 gasser is suitable for towing this trailer. An F150 V6 ECO would be fine if it otherwise appeals to her but she certainly doesn't need a diesel of any kind.
I also mentioned that the best way to determine it's weight would be to load it up and weigh it, but you didn't quote me on that. :H No one is trying to lull anyone into anything. The OP should use the opinions stated by everyone here to determine her own course of action. :R
