- jdc1Explorer II2000 F350 7.3. 160,000 miles. Replaced a few hoses. Always service trans and coolant every 50K. Oil changes (whatever Costco has on sale) every 5K. New fuel filter and clean the air filter every 10K. It just keeps on chugging. I keep in on a trickle charge to keep the batteries up. If I had to put $5,000 into it, it would still be worth it.
While the mileage doesn't match up to my Prius, it is still relatively good. 13mpg towing my 10K 5th wheel and 16mpg+ during routine daily driving (more on highway only, of course). I'll see if one of my grand sons wants it when I decide driving it is a chore. Then they can throw all that high horsepower **** on it while having fun with it. - VTLeeExplorerI have a 1997 7.3 Powerstroke with 5 speedstandard shift. Bought it brand new with the camper package specially for hauling my 9.5 ft. 1993 Sunline. Both are in excellent shape as they are garage kept when not traveling. Truck has 147,000 miles on it and has only been used for camping.
- Kayteg1Explorer IIWhat is HP on 1997 Powerstroke? I remember that as non-turbo version with mechanical IP?
1 more thing I forgot- common on those models was clog on fuel tank strainers.
Somehow the plastic strainers were catching shellacs or whatever, who barely visible to bare eye would clog the fine strainer.
Had to do on both of my trucks and it is not fun on freeway shoulder. - Elk_travelerExplorerMy 7.3L powerstroke is a 1996 and if not mistaken it is a 420ft.lb of torque. It is pure raw diesel power from the ground up. A new Ford diesel the 6.7L engine is and old gasoline converted block that was put in the Ford 392 cu-ft engines in 1962. The International 7.3L diesel was designed from scratch as a diesel engine. The torque delivered is sustained power even under max load whereas the new Ford engines only deliver instant and temporary power and cannot be sustained which is whats make the old 7.3L a better engine to begin with for diesel power. Sure it has a lot of bells and whistles and chinese electronics so you can pay more money to buy but that is all. My truck has less than 77K. I think at the time the first maintenance was scheduled for the 100,000 mile mark which I never reached. I have thus far done all the maintenance myself and as state 90% if miles came from traveling the Rockies of Wyoming, Montana and Colorado towing towing and 5th wheels. The last 5th wheel was a 33 footer weighing 14K and I traveled the Beartooth Highway down from Red Montana with it. After so many years and getting old we gone to motorhome with V10 engine which is a joke compared the to the old 7.3L which is now in the garage and I make the rounds to car shows with it.
- PastorCharlieExplorerThe 1996 7.3 is listed as having 215 HP and 450 ft. lb. torque.
- adamisNomad II
The beauty of these engines was they are so under powered and so over built hence why they are lasting hundreds of thousands of miles. After extensive mods like I have done, I'm pushing between 400hp and 450hp guestimated by the mechanic that did the work (and use to drag race a 7.3 Excursion). I'm not going to the track and I don't make a habit of driving with a lead foot but I very much appreciate the power and responsiveness I now have.
The way I see it about the only significant detractor of the 7.3 is how loud it is in the cab. That is ultimately what may force us to upgrade to something newer. We plan to be on the road for three months at a time and unless I can figure out how to get some significant sound deadening, the wife won't be happy listening to the roar of the engine on the open highway nearly as much as I would. - 7_3driverExplorerEarly 1999 F350, crew cab, dully, 8 foot bed, auto trans, w/tow package, 4.10 limited slip. Current mileage 92,500.
My dad bought it new in Dec. 98. He passed away in 08 but not before taking it to the east coast, Chicago, Alaska (arctic circle) and a few other shorter trips, we live in Central Texas. I inherited it upon his passing.
Sold the 5th wheel, did not want something that big.
Early 2020 I started to do some mods to prep for a camper.
Installed a Mishimoto trans cooler, TS performance chip and piller gauge pod (trans temp,fuel pressure, ETG and boost gauges). Installed Rancho RS9000XL shocks all 4 corners. Already have Firestone air bags that my dad installed.
Found someone selling a complete Torklift camper frame mounts and 20k hitch.
That's the truck.
Bought a 2000 Bigfoot 25c10.6 around Aug. last year and in the process of fixing a few issues. Haven't had a chance to take it out yet.
Wish I could post a picture from my tablet. - jimh406Explorer III
Try this.
http://photoposting.is-great.net/?i=1 - 36guyExplorerFor those of you who think this was fords finest truck, let me say this...I had a 95, stick, bought new, 215 horse, loved that truck to death. Owned it ten years, 9 fan belts, 3 sets of injector O rings, 2 sets of $500 apiece injectors, 2 alternators, dual mass flywheel gave out under warranty, then again at around 100,000 miles,installed a Luc single mass flywheel and clutch set up, was warned by my tranny guy that the input shaft in the getrag 5 speed would fail because of the clutch upgrade, it did, new transmission happened, that was the last straw.
I pulled a cougar 244 fifth, 10,500 lbs, that old truck did a good job.
Sold it, bought an 07 classic body duramax LBZ, still own that, nothing but oil changes, lotsa miles, best truck I've ever owned, I'll never own a ford again. - jimh406Explorer III36guy, sounds like you couldn’t drive a manual shift, didn’t do proper maintenance including oil changes, and modified ito use non OEM parts and it’s Ford’s fault. ;) At leat, you found something you liked. :D That’s really all that matters.
44,029 PostsLatest Activity: Jan 18, 2025
