- Grit_dogNavigator
Cummins12V98 wrote:
4x4ord wrote:
Mud flaps, B&W hitch and weather tech floor mats
HA, nice to hop in and drive these newer trucks! DuraFlaps, B&W, MS2's, Highway Products tool box and now a MaxBrake that's it.
That it is!
And I will be starting to mix the Metamucil in my morning Monster drink apparently too, cause if it had a new anything in the drive, it would stay stock for a while unless the emissions got overly effed up and made me throw them away one day!
As justification for this "leave it stock" pansy behaviour, the diesel pickup is now not the fastest rig in the stable, so I can go beat up on ricers with something else! Just can't smoke em out! - notevenExplorer III
06Fargo wrote:
Equipped the 1 ton with rear air suspension, pyrometer, manifold pressure gauges, mild tow tuner... it still needs better brakes, better parking brake (it's manual trans), slower reverse in 2wd (2wd low switch kit not available for this model)
Next big mod will be the KW mod: Clicky
Oh and I forgot I added BD Diesel exhaust brake...
The KW mod comes with all of the above and up to 2050lbs-ft of torques... - BedlamModeratorMy last truck needed suspension and wheel upgrades for the weight it was carrying but was never a slouch in performance and was left with stock engine and transmission even after the warranty was long gone. My current truck carries all the weight I can load and keeps any speed I ask of it, so it is mostly stock except for the bed, boxes, gooseneck and receiver (give me a break, it is a chassis cab).
After the warranty expires, I may consider modifications to increase durability/reliability/serviceability but see no current need to increase performance. - Cummins12V98Explorer IIII actually got grease in my front driveline U joint today! Had to remove it to do the job. Is that a performance mod????
- rwjejitsExplorer
Grit dog wrote:
06Fargo wrote:
Equipped the 1 ton with rear air suspension, pyrometer, manifold pressure gauges, mild tow tuner... it still needs better brakes, parking brake (it's manual trans), slower reverse in 2wd (2wd low switch kit not available for this model)
^That is pure awesomeness!
Agree. Just the right size. - 24fb_freedomExplorer
BB_TX wrote:
Truck has plenty of power. Not going to do anything that might impact warranty on that expensive engine.
X2 I'm not one to spend 65k, start moding and risk voiding any warranty,lol - kevdenExplorerSwapped from 3.73 to 4.10 gears
Timbren bump stops in rear
Eagle alloy wheels
2nd and 3rd row headrest dvd players
Radar detector
Backup camera
Bullydog gt tuner
K&n cone air filter
Hid low beam headlights
Amber 6" 55 watt hid aux lights turn on with high beam
Replaced defective oem fog lights with military hid lights
Aux trans cooler
All aluminum radiator
Roof basket rack with bike and boat mounts
Telescoping tow mirrors
All it needs now is a limo divider for when the kids are loud! - Grit_dogNavigator
Since the hijack is in full force, lol, what kind of needle is that?
I've been using an actual needle fitting for the front drive shaft but seem to destroy it and only get grease in it about 1of 3 times!
150kmi and it's gotten greased twice I think.....so far so good - HaulinBass02ExplorerEFI Live tuned by Blackbear Performance
Electric cooling fans
Airraid cold air intake
3" lift with 1.5" rear blocks
33x11.5" tires on 20" XD wheels
Added factory power/heated/signal tow mirrors
Soon to have long tube headers, Flopro exhaust, bigger trans cooler and regearing from 3.73 to 4.56 - Old-BiscuitExplorer IIIWhen I was younger I use to do all that mod stuff....
Now I go for dependability/reliability/longevity
Set of ISPRO Gauges (EGT/Tranny Oil Temp/Turbo Boost)
US Gear 4" Exhaust Brake
Louvered 'U' 5th wheel tailgate
Center Console Safe
No other mods needed.
44,029 PostsLatest Activity: Jan 13, 2025
