RoyBell
Jan 30, 2016Explorer
kzspree320 wrote:
I had a 2008 Ram 2500 CTD and recently traded in for a 2015 Ram 2500 with CTD. I love the way the Cummins pulls our 12K loaded fifth wheel. It's my daily driver and does a fine job. It is true that diesel maintenance is higher and repairs, while seldom needed, are more expensive.
If you really want an F250, and are pulling under 8K in your case, why not get the 6.2 gas? If you research the transmission gearing (not axle) on your Tundra, as memory serves me, you would find that the towing power is in no way comparable to the F250 with the 6.2 gas and 4.30 rear end (which is J2807 rated to tow over 15K).
If you think you may be towing heavier, want the additional power (like me), or want the better towing MPG (again like me), then the diesel is a fine way to go. I chose the Ram and Cummins because it still has the CP3 fuel pump and 2 fuel filters, and based on my prior truck the towing and reliability was great.
The CP4 fuel pump used on the Ford 6.7 and Duramax diesels create a high repair cost risk I didn't want. That said, I realize the failure rate may be low, but it's a risk I didn't want. If you don't know what I'm referring to, do a little research. Look at user Ricatic threads on his truck. This failure is not that common, but it's expensive.
Again, I think my diesel is a fine daily driver. Good luck. Keith
Thank you for the info.
As for Ford vs Toyota transmission, fords are more aggressive down low. Toyota also has 4.30 rear axle. Trans does look good for towing, but the lack of low end torque on their gas motor, plus heavier curb weight makes me think performance will be close to the Tundra. I should note that I am a power junky so more power is good :)
6R140 Gear Ratios:
First - 3.97:1
Second - 2.32:1
Third - 1.52:1
Fourth - 1.15:1
Fifth - 0.86:1
Sixth - 0.67:1
AB60E Gear Ratios:
First - 3.33:1
Second - 1.96:1
Third - 1.35:1
Fourth - 1.00:1
Fifth - 0.72:1
Sixth - 0.58:1
