RoyBell
Jan 30, 2016Explorer
Greene728 wrote:RoyBell wrote:Greene728 wrote:
I'm not sure where you are getting your information regarding the Big 3 and their new gas engines and taking a step backwards. When comparing them with your Tundra ( which admittedly is a fine truck for it's intended purpose ) either of them with gas engine's in 3/4 or better yet 1 ton configuration will out tow the day lights out of your Tundra, and get comparable mpg while doing it. It's far more than just engine HP and torque numbers. It's bigger frame, bigger brakes, different gearing, better transmission, higher payload, better suspension, etc... No stepping backwards at all! And I'd even say that for the weight your towing and being a DD that the gas would be your best bet. Now if your planning to upgrade your RV in the future and don't mind the extra costs associated with the diesel then go for it. And yes, I'm speaking from first hand experience. Had a 2012 F-250 with the 6.2 Gasser and pull a 5th at around 9500# loaded. Truck did fine other than less than stellar gas mileage when towing which is to be expected. I know have the truck in my signature that the 250 was traded in on and it is also my DD. Towing and fuel mileage between the 2 is no comparison and apples to oranges. I had diesels up until the gas 250 since 2003 and just missed being in a diesel trucks and was just not able to adjust to the gas engine towing. So far absolutely no issues and no regrets in 3.5 month's and 3500 miles.
Re-read my post. I said step back in power.
Toyota 5.7: 381hp 5600 rpm/ 401tq 3600 rpm
GM 6.0: 360hp 5400 rpm/ 380tq 4200 rpm
Ford 6.2: 385hp 5500 rpm/405tq 4500 rpm
Dodge 6.4: 410hp 5600rpm/ 429 tq 4000 rpm
They are all right in the same ball park, but the Dodge being the highest. But, Toyotas 5.7 makes torque lower than all of them. Then add the heavier curb weight of the 3/4 ton and performance will be down compared to what I got now which , to me, is not acceptable.
I understand what you meant. But it's not just that comparison. Post the payload and towing comparisons of each. Sure, unloaded performance may not be what you are accustomed to, but towing will be significantly different and improved. You want to get off the line and from stop light to stop light faster with sub par towing, or do you want to have a all around better towing experience while still having a capable and dependable DD that will get you from point A to point B just a tick slower? You simply cannot compare gas 1\2 ton truck to gas 3\4 or 1 ton truck for towing no matter what the HP and Torque numbers say! Especially a Toyota half ton as they are notoriously weak in payload and towing ability. Best of luck with your decision.
I want both towing ability and power, which is why I am thinking Diesel. I get that the 3/4 will tow better overall, which is why I am looking at them. Point being, going down in performance to get better towing ability is not something I am willing to entertain at this point. I towed 6 times last year with my Tundra and new TT. It isn't that terrible to begin with. Just right on the edge. Taking a hit in performance when I drive it empty most of the time anyways, just doesn't make sense.
Yes I want my cake and eat it too. @ $52-60K you shouldn't have to compromise when purchasing a vehicle.
