danrclem
Aug 30, 2019Explorer
johndeerefarmer wrote:AlmostAnOldGuy wrote:
As you already know the HDPP has heavier axles, heavier suspension, heavier shocks and LT E tires. Provided you were staying within rear axle rating and you already had LT E tires I would consider Timbrens which will provide additional suspension without impacting the unloaded ride and putting on some Bilstien shocks. That would give you a pretty good idea of how the HDPP would handle before making a large $ decision. I would run a good WD hitch.
Good luck,
Stu
I have Bilstein 4600's on the rear, I haven't replaced the front yet.
I just can't imagine how having a stiffer suspension would help with stability in the wind- which is my problem. Now if I was hitting a bump and it was bouncing excessively or from side to side I would say I needed heavier springs,etc. That's not the problem.
I have bad tendonitis in both elbows, the solid front axle of the F250 transfers dips, bumps in the road back to the steering wheel. This excessive movement of the steering wheel increases the inflammation in my elbows so I can't drive as far. The EPS in the F150 is way better. On the F250 (I have had several) I have tried dual steering stabilizers as well as the Bilstein adjustable ($475 one). They don't help much at all
Both of my campers are fifth wheels
Does your F250 have the snow plow package? If it does it may be why it transfers dips and bumps to the steering wheel. I have the snow plow package and the only place that I notice unwanted transfers is when I go over a patch of rough road but I don't have tendonitis so I may not notice it as much. There was a person on here who switched his front snow plow package springs out for lighter ones with success. I hope that you're able to find something that will work for you.
44,066 PostsLatest Activity: Apr 16, 2026
